Question: Variable assignment issue - Arrays
I am having a problem with variable assignment.
output 15 should be:
test :=[1]
[2]
[1 1]
At some point, the array test is being overwritten even though in my proceedure I use only local variables.
Warning, `tempvec` is implicitly declared local to procedure `Gen1`
Warning, `tempvec` is implicitly declared local to procedure `GenAdd`
Warning, `i` is implicitly declared local to procedure `FindFirst`
Warning, `tempvec` is implicitly declared local to procedure `FindFirst`
Warning, `n` is implicitly declared local to procedure `FindFirst`
Warning, `temp` is implicitly declared local to procedure `FindFirst`
Warning, `temp` is implicitly declared local to procedure `Findmax`
Warning, `n` is implicitly declared local to procedure `Findmax`
Warning, `tempvec` is implicitly declared local to procedure `Findmax`
Warning, `i` is implicitly declared local to procedure `Findmax`
Warning, `tempvec` is implicitly declared local to procedure `GenVec`
Warning, `tempvec2` is implicitly declared local to procedure `GenVec`
Warning, `ftemp` is implicitly declared local to procedure `GenVec`
Warning, `i` is implicitly declared local to procedure `Genlist`
Warning, `tempvec` is implicitly declared local to procedure `Genlist`
Warning, `coverlist` is implicitly declared local to procedure `Genlist`
Warning, `atmax` is implicitly declared local to procedure `Genlist`
Warning, `tempvec2` is implicitly declared local to procedure `Genlist`
Warning, `temp` is implicitly declared local to procedure `Genlist`
(14)
(15)
Download PosetMaple.mw
(14)
(15)
I'm having an variable assignment issue for Arrays:
Output 15 should look like:
