Question: How to use writedata to a series of files
Hi,
  Suppose I would like to use writedata for a series of files, e.g. test1.txt, test2.txt, test3.txt.
I tried
a_min:=1;a_max:=3;
b_min:=1;b_max:=3;
A:=array(a_min..a_max,b_min..b_max);
for i from a_min to a_max do
  for j from b_min to b_max do
     A[i,j]:=i*j;
  end do;
end do;
for i from 1 to 3 do
  file_name:=`test||i`;
  writedata[APPEND](file_name,A);
end do;
Seems "||" inside `` does not work, is there any robust solution for this issue?
Thank you very much
