Question: What is causing this error with InitialValueProblem command?
I'm trying to approximate the solution of an IVP using Euler's method in the InitialValueProblem command and I keep getting this error (see attached worksheet). Can someone explain why? Thanks!
with(Student[NumericalAnalysis]):
InitialValueProblem((D(y))(t) = t*y(t)+1/y(t), y(0) = 3, t = 2, method = euler, numsteps = 5, output = solution)
Error, (in dsolve/numeric) array output cannot be obtained for problems containing global variables
Download ivp_error.mw
