Question: Determination of the Lagrange multiplier for variational iteration method
Hi, for determination of the Lagrange multiplier λ(ξ ), I'm trying to use of integration by parts:
To obtain the first integral (first order respet to u) , it's simple.
But for the socond integral (second order respect to u), I could not find a direct solution and I had to solve by multi-steps.
For high orders,this can be  frustrating and time-consuming
Is there a simpler solution ??
Here is my code:
with(IntegrationTools):
For firs order:
Order1_main:=Int(lambda(s)*diff(u(s),s),s)
Int(lambda(s)*(diff(u(s), s)), s)
Order1_ans:=Parts(Order1_main, lambda(s))
u(s)*lambda(s)-(Int(u(s)*(diff(lambda(s), s)), s))
And for second order:
Order2_main:=Int(lambda(s)*diff(u(s),s,s),s)
Int(lambda(s)*(diff(diff(u(s), s), s)), s)
Order2_parts:=Parts(Order2_main, lambda(s))
lambda(s)*(diff(u(s), s))-(Int((diff(u(s), s))*(diff(lambda(s), s)), s))
By copy and past the  tow parts of above equaion :
Order2_p1:=lambda(s)*(diff(u(s), s));
Order2_p2:=Int((diff(u(s), s))*(diff(lambda(s), s)), s)
Order2_p2_ans:=Parts(Order2_p2,diff(lambda(s),s))
u(s)*(diff(lambda(s), s))-(Int(u(s)*(diff(diff(lambda(s), s), s)), s))
NULLOrder2_ans := Order2_p1-Order2_p2_ans;
lambda(s)*(diff(u(s), s))-u(s)*(diff(lambda(s), s))+Int(u(s)*(diff(diff(lambda(s), s), s)), s)
Order3_main:=Int(lambda(s)*diff(u(s),s,s,s),s)
Int(lambda(s)*(diff(diff(diff(u(s), s), s), s)), s)
Download _Integration_by_parts.mw
Hear is an example :
Is that possible to get equation.4 in the following example by Maple?
