Question: When running a for do cycle the first two solutions are the same
Hi,
when running a for do cycle the first two solutions are exact the same numbers, which is not correct. Can someone plesa help me fix this problem?
Thanks a lot.
tmin:=10: #°C
tmax:=70: #°C
Tmin:=tmin+273.15:
Tmax:=tmax+273.15:
T:='T':
i:=0:
for T from Tmin by 2 to Tmax+1.25 do
i:=i+1:
a12:=2305.28444347652 - 9.14490843016421*T + 0.00680052257590234*T^2:
a21:=-6665.24838284836 + 46.0897018087247*T - 0.0694991633494123*T^2:
alfa:=0.3:
x2:=1-x1:
lng1:=x2^2*(tau21*(G21/(x1+x2*G21))^2+tau12*(G12/((x2+x1*G12)^2))):
lng2:=x1^2*(tau12*(G12/(x2+x1*G12))^2+tau21*(G21/((x1+x2*G21)^2))):
G12:=exp(-alfa*tau12):
G21:=exp(-alfa*tau21):
tau12:=a12/T:
tau21:=a21/T:
lnga1:=subs(x1=xa1,lng1):
lngb1:=subs(x1=xb1,lng1):
lnga2:=subs(x1=xa1,lng2):
lngb2:=subs(x1=xb1,lng2):
r1:=lnga1+ln(xa1)=lngb1+ln(xb1):
r2:=lnga2+ln(1-xa1)=lngb2+ln(1-xb1):
r:=fsolve({r1,r2},{xa1=0..0.22,xb1=0.22..1}):
assign(r):
xA1[i]:=xa1: xB1[i]:=xb1:
print(i,T,xA1[i],xB1[i]);
unassign('r1','r2','r','xa1','xb1'):
od:
1, 283.15, 0.4086195757e-1, .7650860222
2, 285.15, 0.4086195757e-1, .7650860222
3, 287.15, 0.4109304612e-1, .7564109743
4, 289.15, 0.4094687104e-1, .7455613500
5, 291.15, 0.4092946881e-1, .7345259571
6, 293.15, 0.4103899093e-1, .7233142804
7, 295.15, 0.4127502108e-1, .7119337099
8, 297.15, 0.4163857511e-1, .7003892047
9, 299.15, 0.4213210541e-1, .6886831535
10, 301.15, 0.4275956094e-1, .6768151230
11, 303.15, 0.4352648605e-1, .6647816285
12, 305.15, 0.4444014482e-1, .6525760020
13, 307.15, 0.4550971743e-1, .6401880864
14, 309.15, 0.4674655982e-1, .6276039487
15, 311.15, 0.4816452203e-1, .6148056135
16, 313.15, 0.4978038925e-1, .6017705621
17, 315.15, 0.5161445760e-1, .5884711603
18, 317.15, 0.5369126350e-1, .5748739966
19, 319.15, 0.5604059678e-1, .5609387793
20, 321.15, 0.5869882131e-1, .5466171048
21, 323.15, 0.6171072215e-1, .5318505354
22, 325.15, 0.6513208559e-1, .5165679944
23, 327.15, 0.6903339246e-1, .5006820935
24, 329.15, 0.7350533414e-1, .4840835134
25, 331.15, 0.7866732744e-1, .4666324128
26, 333.15, 0.8468127263e-1, .4481446382
27, 335.15, 0.9177527543e-1, .4283678555
28, 337.15, .1002878317, .4069372077
29, 339.15, .1107594115, .3832836608
30, 341.15, .1241550103, .3564111567
31, 343.15, .1425634130, .3241972432
Download lle.mw
lle.mw
