Question: exception using solve. How to catch when using assertlevel?
I am getting an exception divide by zero using solve. The problem is that when using kernelopts('assertlevel'=2):  I am no longer able to catch the exception in a catch try.
Removing kernelopts('assertlevel'=2):  I can catch the exception.
But I need to use kernelopts('assertlevel'=2): in my program.
Is there a way to keep kernelopts('assertlevel'=2): and still catch exception thrown by solve?
Is this a bug in solve? And why using kernelopts('assertlevel'=2): prevents catching the exception?
Using Maple 2021.2 on windows 10. Worksheet attached.
 exception generated
trial_solution_constants:=[A[1]];
eq:=-A[1]-exp(x^2)*exp(-x^2) = 0;
solve(identity(eq,x),trial_solution_constants)
[A[1]]
Error, (in unknown) numeric exception: division by zero
Using assertlevel, now unable to catch exception
interface(warnlevel=4);
3
try
catch:
   print("error happend ",lastexception);
end try;
print(" I am here");
[A[1]]
Error, (in unknown) assertion failed
" I am here"
Not Using assertlevel now can catch exception
3
try
catch:
end try;
[A[1]]
"error happend ", unknown, "numeric exception: division by zero"
" I am here"
Download march_8_2021_solve.mw
Update Sept 7,2022
FYI, here is another internal exception generated by solve which shows only when kernelopts('assertlevel'=2): is set, and which can not be trapped using try/catch. May be this could be fixed in future version of Maple.
Worksheet attached.
`Standard Worksheet Interface, Maple 2022.1, Windows 10, May 26 2022 Build ID 1619613`
Physics:-Version();
`The "Physics Updates" version in the MapleCloud is 1314 and is the same as the version installed in this computer, created 2022, September 2, 15:54 hours Pacific Time.`
3
eq:=1 = -X*(-(Y^2*exp(X*Y)*exp(X*y0)*exp(x0*Y)*exp(x0*y0)+2*exp(X*Y)*y0*exp(X*y0)*exp(x0*Y)*exp(x0*y0)*Y+exp(X*Y)*y0^2*exp(X*y0)*exp(x0*Y)*exp(x0*y0))/(exp(X*Y)*exp(X*y0)*exp(x0*Y)*exp(x0*y0)*X+exp(X*Y)*exp(X*y0)*exp(x0*Y)*exp(x0*y0)*x0+2*Y+2*y0)+(exp(X*Y)*exp(X*y0)*exp(x0*Y)*exp(x0*y0)*Y+exp(X*Y)*exp(X*y0)*exp(x0*Y)*exp(x0*y0)*y0+1)/(exp(X*Y)*exp(X*y0)*exp(x0*Y)*exp(x0*y0)*X+exp(X*Y)*exp(X*y0)*exp(x0*Y)*exp(x0*y0)*x0+2*Y+2*y0)^2*(Y*exp(X*Y)*exp(X*y0)*exp(x0*Y)*exp(x0*y0)*X+exp(X*Y)*y0*exp(X*y0)*exp(x0*Y)*exp(x0*y0)*X+exp(X*Y)*exp(X*y0)*exp(x0*Y)*exp(x0*y0)+Y*exp(X*Y)*exp(X*y0)*exp(x0*Y)*exp(x0*y0)*x0+exp(X*Y)*y0*exp(X*y0)*exp(x0*Y)*exp(x0*y0)*x0))/Y/(-(Y*exp(X*Y)*exp(X*y0)*exp(x0*Y)*exp(x0*y0)*X+exp(X*Y)*y0*exp(X*y0)*exp(x0*Y)*exp(x0*y0)*X+exp(X*Y)*exp(X*y0)*exp(x0*Y)*exp(x0*y0)+Y*exp(X*Y)*exp(X*y0)*exp(x0*Y)*exp(x0*y0)*x0+exp(X*Y)*y0*exp(X*y0)*exp(x0*Y)*exp(x0*y0)*x0)/(exp(X*Y)*exp(X*y0)*exp(x0*Y)*exp(x0*y0)*X+exp(X*Y)*exp(X*y0)*exp(x0*Y)*exp(x0*y0)*x0+2*Y+2*y0)+(exp(X*Y)*exp(X*y0)*exp(x0*Y)*exp(x0*y0)*Y+exp(X*Y)*exp(X*y0)*exp(x0*Y)*exp(x0*y0)*y0+1)/(exp(X*Y)*exp(X*y0)*exp(x0*Y)*exp(x0*y0)*X+exp(X*Y)*exp(X*y0)*exp(x0*Y)*exp(x0*y0)*x0+2*Y+2*y0)^2*(X^2*exp(X*Y)*exp(X*y0)*exp(x0*Y)*exp(x0*y0)+2*exp(X*Y)*exp(X*y0)*x0*exp(x0*Y)*exp(x0*y0)*X+exp(X*Y)*exp(X*y0)*x0^2*exp(x0*Y)*exp(x0*y0)+2)):
try
     sol:=solve(identity(eq,X),[x0, y0]);
catch:
     print("exception");
end try;
Download solve_exception.mw
