Question: New problem using suggested solution in new setup with _self and Object
The suggested solution in the answer https://mapleprimes.com/questions/234325-Use-Of-self--Inside-Object-Constructor  worked OK in the setup shown in that question.
But it does not work when putting the constructor inside overload
Here is an example where it works (i.e. by removing the type from _self as suggested in the above answer)
person:=module()
    option object;
    local name::string:="";
    #notice no _self::person, just _self
    export ModuleCopy::static:= proc( _self, proto::person, the_name::string, $ )
           name:= the_name;
    end proc;
end module;
p:=Object(person,"me")
The above works. But since I have different constructors, once I put the above inside overload, using the same exact syntax, now the error comes back
person:=module()
    option object;
    export ModuleCopy::static:= overload(
       proc( _self, proto::person, the_name::string, $ ) option overload;
           name:= the_name;
      end proc
end module;
Error, static procedure `ModuleCopy` refers to non-static local or export `name::string` in surrounding scope
I did not expect that using overload will cause any change to how it behaves. Is this a bug?
Below is worksheet also.
`Standard Worksheet Interface, Maple 2022.1, Windows 10, May 26 2022 Build ID 1619613`
person:=module()
    option object;
           name:= the_name;
    end proc;
end module;
_m2950059551392
_m2950172920000
person:=module()
    option object;
           name:= the_name;
      end proc
end module;
_m2950059551392
Download OO_version.mw
