Question: Alternative Argument spelling in a procedure
This is something I use a fair bit. I have procedures with alternative spelling options for the colours Red Green and Blue.
Have shown a single example copied from  an overloaded procedure. It there a nicer way of handling this than what I am doing?
There is a section in help under "Procedure Parameter Declarations" on "Indexed Keyword Parameters"  but I don't see how to use it here. These procedures are used inside a package.
GeomClr:="Blue";  # can be "Blue", "blue", "B", "b"  or;
                  #        "Green", "green", "G", "g"  or;
                  #        "Red2, "red", "R", "r";
Prntmsg:="y" ; #  or anything that is not"y"
"Blue"
"y"
spread:=proc(p0::{satisfies(s -> type(s, [algebraic $ 2])),'Vector[row]'(2, algebraic)},
              p1::{satisfies(s -> type(s, [algebraic $ 2])),'Vector[row]'(2, algebraic)},
              clr::`string`:= GeomClr,
              prnt::`string`:=Prntmsg)
           option overload;
           uses LinearAlgebra;
           #print(clr,p0,p1);
           if clr="b" or clr="B" or clr="blue" or clr="Blue" then
              if prnt="y" then
                print("Spread 2 [x,y] Points/Vectors wrt origin Blue");
              end if;
               return 1 - BilinearForm(p0, p1, conjugate = false)^2/(BilinearForm(p0, p0, conjugate = false)*BilinearForm(p1, p1, conjugate = false));
           elif clr="g" or clr="G" or clr="green" or clr="Green" then
              if prnt="y" then
               print( "Spread 2 [x,y] Points/Vectors wrt origin Green");
              end if;
               return -1/4*(p0[1]*p1[2] - p0[2]*p1[1])^2/(p0[1]*p0[2]*p1[1]*p1[2]);
           elif clr="r" or clr="R" or clr="red" or clr="Red" then
              if prnt="y" then
               print( "Spread 2 [x,y] Points/Vectors wrt origin Red");
               end if;
               return -(p0[1]*p1[2] - p0[2]*p1[1])^2/((p0[1]^2 - p0[2]^2)*(p1[1]^2 - p1[2]^2));
          end if;
sb:=spread(<3|2>,<4|-5>);
529/533
sg:=spread(<3|2>,<4|-5>,"g");
529/480
sr:=spread(<3|2>,<4|-5>,"r");
529/45
1/sb+1/sr+1/sg
2
sr:=spread(<3|2>,<4|-5>,"r","n");
529/45
Download Q_2024-02-09_Alternative_Spelling_in_Proc.mw
This has been branched into the following page(s):
