Question: why simplify does not work on this example?
These  are good example(s)  why I think Maple's simplify needs to be improved.
Example 1
Given an expression which is zero for nonnegative x, one would expect simplify to simplify it to zero when told that x is positive.
But nothing I tried with simplify worked. combine  figured it out.
But why? Is this not the job of simplify?
The expression is
e:=x-1/4*(-2+2*(4*x^2+1)^(1/2))^(1/2)*(2+2*(4*x^2+1)^(1/2))^(1/2);
Here is worksheet
x-(1/4)*(-2+2*(4*x^2+1)^(1/2))^(1/2)*(2+2*(4*x^2+1)^(1/2))^(1/2)
coulditbe(e=0);
true
#we see it is zero for x>=0
plot(e,x=-3..3)
simplify(e) assuming x>=0;
simplify(e,size) assuming x>=0;
expand(e) assuming x>=0;
simplify(e,sqrt) assuming x>=0;
simplify(e,symbolic) assuming x>=0;
combine(e) assuming x>=0;
0
Compare some other software on this same problem
It should be as simple as the above in Maple.
A user should not have to try 100 different commands in Maple to find which works.
simplify should have done it in first place. What Am I overlooking here?
Maple 2024
Download why_simplify_do_not_work_example.mw
EXAMPLE 2
In this example the expression is zero for x<0. Here nothing worked for me. This is challenge for Maple experts here to find the command to simplify this to zero.
I know it is zero for x<0.
e := -1/2*(-2*x*sqrt(4*x^2 + 1) + (16*x^3*sinh(3/2*arcsinh(2*x)) - 8*x^2*cosh(3/2*arcsinh(2*x))*sqrt(4*x^2 + 1) + 4*sinh(3/2*arcsinh(2*x))*x - cosh(3/2*arcsinh(2*x))*sqrt(4*x^2 + 1))*sqrt(-2 + 2*sqrt(4*x^2 + 1)))/sqrt(4*x^2 + 1)
24064
Physics:-Version();
`The "Physics Updates" version in the MapleCloud is 1752 and is the same as the version installed in this computer, created 2024, May 31, 18:17 hours Pacific Time.`
e:=-1/2*(-2*x*sqrt(4*x^2 + 1) + (16*x^3*sinh(3/2*arcsinh(2*x)) - 8*x^2*cosh(3/2*arcsinh(2*x))*sqrt(4*x^2 + 1) + 4*sinh(3/2*arcsinh(2*x))*x - cosh(3/2*arcsinh(2*x))*sqrt(4*x^2 + 1))*sqrt(-2 + 2*sqrt(4*x^2 + 1)))/sqrt(4*x^2 + 1);
-(1/2)*(-2*x*(4*x^2+1)^(1/2)+(16*x^3*sinh((3/2)*arcsinh(2*x))-8*x^2*cosh((3/2)*arcsinh(2*x))*(4*x^2+1)^(1/2)+4*sinh((3/2)*arcsinh(2*x))*x-cosh((3/2)*arcsinh(2*x))*(4*x^2+1)^(1/2))*(-2+2*(4*x^2+1)^(1/2))^(1/2))/(4*x^2+1)^(1/2)
plot(e,x=-10..3);
coulditbe(e=0)
true
simplify(e) assuming x<0;
-8*((cosh((3/2)*arcsinh(2*x))*(-(1/2)*x^2-1/16)*(4*x^2+1)^(1/2)+sinh((3/2)*arcsinh(2*x))*x*(x^2+1/4))*(-2+2*(4*x^2+1)^(1/2))^(1/2)-(1/8)*x*(4*x^2+1)^(1/2))/(4*x^2+1)^(1/2)
simplify(e,symbolic) assuming x<0;
combine(e) assuming x<0;
simplify(e,arctrig) assuming x<0;
simplify(e,sqrt) assuming x<0;
simplify(normal(e),sqrt) assuming x<0;
simplify(normal(e, expanded)) assuming x<0;
simplify(radnormal(e)) assuming x<0;
(1/8)*((4*x^2+(4*x^2+1)^(1/2)+1)*(-2+2*(4*x^2+1)^(1/2))-64*x*((1/2)*cosh((3/2)*arcsinh(2*x))*(-1/8-x^2)*(4*x^2+1)^(1/2)+sinh((3/2)*arcsinh(2*x))*x*(x^2+1/4))*(-2+2*(4*x^2+1)^(1/2))^(1/2))/((4*x^2+1)^(1/2)*x)
simplify(evala(e)) assuming x<0;
Using some other software gives
I'd like to find command to do the same in Maple. i.e. simplify it to zero. What else to try?
Download why_simplify_do_not_work_example_2.mw
