Question: Result of odetest changes depending on previous command used.
If I do    odetest(...,odeA) I get correct result. But if I do    odetest(...,odeB);  odetest(...,odeA);   now it gives wrong output for the odeA one.
Same exact code. It just depends on the call done before it.
Why would issuing a command before changes the output of odetest? It seems Maple remembers something from last call. But I have no idea how to fix this.
Is there a way to tell odetest not to remember or cache any results from last calls? i.e. Can I clear its remember table before calling odetest??
This is messing all my testing now since I get different result each time depending on which call was made before. I can't do restart before testing each ode, since this is done in a loop.  I just need a way to tell Maple to clear its internal cache so that each call to odetest is not affected by last call result.
Doing forget(odetest); before the call had no effect.
Reported to Maplesoft.
Worksheet below
#EXAMPLE 1
ode:=x*diff(y(x),x)^n=0;
sol:=dsolve(ode);
odetest(sol,ode);
x*(diff(y(x), x))^n = 0
y(x) = c__1
0
ode:=diff(y(x),x)^n=0;
sol:=dsolve(ode);
odetest(sol,ode);
y(x) = c__1
0^n
##EXAMPLE 1 repeated. Why now different result??
sol:=dsolve(ode);
odetest(sol,ode);
y(x) = c__1
x*0^n
Download why_different_result_from_odetest_june_6_2024.mw
Update
FYI, I got email from Maplesupport that Maple R&D group will look at this issue.
So hopefully this will be fixed in a future version of Maple.
I am not able to find a workaround but doing tracing I see that odetest does rememebr something from last call but have no idea to fix this myself.
