Question: How to reproduce this nice output format
When executing the attached work sheet, the output
changes to
Why is that (local seetings maybe?) and how to reproduce the former, more compact output?
Copy-pasted from the wonderful:
Advanced Engineering Mathematics
Dr. Robert J. Lopez
Emeritus Professor of Mathematics
Maple Fellow
© Maplesoft, a division of Waterloo Maple Inc., 2023
This is obtained in Maple by writing the differential equation
q := diff(x(t),t) = k*(40 - 16/18*x(t))*(8 - 2/18*x(t));
diff(x(t), t) = k*(40-(8/9)*x(t))*(8-(1/9)*x(t))
and solving via the syntax
X := simplify(rhs(dsolve({q,x(0)=0},x(t))));
(-360+360*exp((8/3)*t*k))/(8*exp((8/3)*t*k)-5)
The differential equation is actually separable, and can be solved with the techniques of elementary calculus discussed in Section 3.1.
If an observation provides the data that at time t = 1 there were 6 grams of water, then the constant of proportionality k can be computed.  In Maple, the data point gives the equation
eq := eval(X, t=1) = 6;
(-360+360*exp((8/3)*k))/(8*exp((8/3)*k)-5) = 6
whose solution is
K := solve(eq,k);
(3/8)*ln(55/52)
Download Output_formated_with_rational_factor_.mw
