Question: odeadvisor, possible wrong classification on first order ode
odeadvisor says that this ode is _homogeneous, `class A`, but I am not able to verify this. Also when asking dsolve to solve it as 'homogeneous' it returns no solution.
This type is described in https://www.maplesoft.com/support/help/maple/view.aspx?path=odeadvisor%2fhomogeneous
Here is worksheet with my tries.
Would someone be able to confirm if this is really an _homogeneous, `class A` ?
my own code checking says no.  But if it is, then why dsolve do not solve it when asking it to use homogeneous method? Is the method I asked it to use it do not apply to class A?
30348
ode:=x + diff(y(x), x)*y(x)*(2*diff(y(x), x)^2 + 3) = 0;
DEtools:-odeadvisor(ode);
x+(diff(y(x), x))*y(x)*(2*(diff(y(x), x))^2+3) = 0
[[_homogeneous, `class A`], _dAlembert]
infolevel[dsolve]:=5;
dsolve(ode,y(x))
5
Methods for first order ODEs:
   *** Sublevel 2 ***
   -> Solving 1st order ODE of high degree, 1st attempt
   trying 1st order WeierstrassP solution for high degree ODE
   trying 1st order WeierstrassPPrime solution for high degree ODE
   trying 1st order JacobiSN solution for high degree ODE
   trying 1st order ODE linearizable_by_differentiation
   trying differential order: 1; missing variables
   trying simple symmetries for implicit equations
   <- symmetries for implicit equations successful
y(x) = -((1/2)*I)*2^(1/2)*x, y(x) = ((1/2)*I)*2^(1/2)*x, y(x) = RootOf(-ln(x)+Intat(-(-2*((_a^2-(2*_a^2+1)^(1/2)+1)*_a/(2*_a^2+1)^(3/2))^(2/3)*_a^2+2*((_a^2-(2*_a^2+1)^(1/2)+1)*_a/(2*_a^2+1)^(3/2))^(1/3)*_a^3-((_a^2-(2*_a^2+1)^(1/2)+1)*_a/(2*_a^2+1)^(3/2))^(2/3)+_a*((_a^2-(2*_a^2+1)^(1/2)+1)*_a/(2*_a^2+1)^(3/2))^(1/3)+_a^2)/(((_a^2-(2*_a^2+1)^(1/2)+1)*_a/(2*_a^2+1)^(3/2))^(1/3)*(2*_a^4+3*_a^2+1)), _a = _Z)+c__1)*x, y(x) = RootOf(-2*ln(x)+Intat(((2*I)*((_a^2-(2*_a^2+1)^(1/2)+1)*_a/(2*_a^2+1)^(3/2))^(2/3)*3^(1/2)*_a^2+I*((_a^2-(2*_a^2+1)^(1/2)+1)*_a/(2*_a^2+1)^(3/2))^(2/3)*3^(1/2)-2*((_a^2-(2*_a^2+1)^(1/2)+1)*_a/(2*_a^2+1)^(3/2))^(2/3)*_a^2-4*((_a^2-(2*_a^2+1)^(1/2)+1)*_a/(2*_a^2+1)^(3/2))^(1/3)*_a^3+I*3^(1/2)*_a^2-((_a^2-(2*_a^2+1)^(1/2)+1)*_a/(2*_a^2+1)^(3/2))^(2/3)-2*_a*((_a^2-(2*_a^2+1)^(1/2)+1)*_a/(2*_a^2+1)^(3/2))^(1/3)+_a^2)/(((_a^2-(2*_a^2+1)^(1/2)+1)*_a/(2*_a^2+1)^(3/2))^(1/3)*(2*_a^4+3*_a^2+1)), _a = _Z)+2*c__1)*x, y(x) = RootOf(-2*ln(x)-Intat(((2*I)*((_a^2-(2*_a^2+1)^(1/2)+1)*_a/(2*_a^2+1)^(3/2))^(2/3)*3^(1/2)*_a^2+I*((_a^2-(2*_a^2+1)^(1/2)+1)*_a/(2*_a^2+1)^(3/2))^(2/3)*3^(1/2)+I*3^(1/2)*_a^2+2*((_a^2-(2*_a^2+1)^(1/2)+1)*_a/(2*_a^2+1)^(3/2))^(2/3)*_a^2+4*((_a^2-(2*_a^2+1)^(1/2)+1)*_a/(2*_a^2+1)^(3/2))^(1/3)*_a^3+((_a^2-(2*_a^2+1)^(1/2)+1)*_a/(2*_a^2+1)^(3/2))^(2/3)+2*_a*((_a^2-(2*_a^2+1)^(1/2)+1)*_a/(2*_a^2+1)^(3/2))^(1/3)-_a^2)/(((_a^2-(2*_a^2+1)^(1/2)+1)*_a/(2*_a^2+1)^(3/2))^(1/3)*(2*_a^4+3*_a^2+1)), _a = _Z)+2*c__1)*x
dsolve(ode,y(x),[homogeneous])
Classification methods on request
Methods to be used are: [homogeneous]
Successful isolation of dy/dx: 3 solutions were found. Trying to solve each resulting ODE.
* Tackling ODE using method: homogeneous
--- Trying classification methods ---
trying homogeneous types:
sol:=PDEtools:-Solve(ode,diff(y(x),x));
diff(y(x), x) = (1/2)*2^(1/3)*(-y(x)^2*2^(1/3)+((-x+(2*y(x)^2+x^2)^(1/2))*y(x)^2)^(2/3))/(y(x)*((-x+(2*y(x)^2+x^2)^(1/2))*y(x)^2)^(1/3)), diff(y(x), x) = -(1/4)*2^(1/3)*(I*3^(1/2)*y(x)^2*2^(1/3)+I*3^(1/2)*((-x+(2*y(x)^2+x^2)^(1/2))*y(x)^2)^(2/3)-y(x)^2*2^(1/3)+((-x+(2*y(x)^2+x^2)^(1/2))*y(x)^2)^(2/3))/(y(x)*((-x+(2*y(x)^2+x^2)^(1/2))*y(x)^2)^(1/3)), diff(y(x), x) = (1/4)*2^(1/3)*(I*3^(1/2)*y(x)^2*2^(1/3)+I*3^(1/2)*((-x+(2*y(x)^2+x^2)^(1/2))*y(x)^2)^(2/3)+y(x)^2*2^(1/3)-((-x+(2*y(x)^2+x^2)^(1/2))*y(x)^2)^(2/3))/(y(x)*((-x+(2*y(x)^2+x^2)^(1/2))*y(x)^2)^(1/3))
map(X->DEtools:-odeadvisor(X),[sol])
[[[_homogeneous, `class A`], _dAlembert], [[_homogeneous, `class A`]], [[_homogeneous, `class A`]]]
map(X->dsolve(X,y(x),[homogeneous]),[sol])
Download checking_homogo_ode_type_june_18_2024.mw
