Question: Maple 2024.1 locks up completely when using timelimit with a large output and interface(typesetting = standard) so that the output is fully displayed
I called dsolve with timelimit on this ode.  All of Maple instantly locks up.
I do not mean the worksheet, but everything. I have each worksheet using its own engine,. Not able to open new worksheet, nothing clicks. The whole front end locks up. Can't click on anything.
Killing every mserver.exe does not even resolve this. I had to terminate all of Maple from the task manager. The strange thing, is that looking at task manager I see mserver.exe doing nothing. zero CPU. Only the front end process is at high CPU (the one with the Java icon).  It looks like the Java frontend is locked up for some reason.
Do others see the same thing? does this happen on the mac also? Please make sure to save all your work before trying to run this on your PC.
Maple 2024.1 on windows 10. This is first order Riccati ode.
Physics:-Version();
`The "Physics Updates" version in the MapleCloud is 1774 and is the same as the version installed in this computer, created 2024, July 16, 17:18 hours Pacific Time.`
ode:=(a2*x^2+b2*x+c2)*diff(y(x),x)=y(x)^2+(a1*x+b1)*y(x)+a0*x^2+b0*x+c0;
(a2*x^2+b2*x+c2)*(diff(y(x), x)) = y(x)^2+(a1*x+b1)*y(x)+a0*x^2+b0*x+c0
DEtools:-odeadvisor(ode);
[_rational, _Riccati]
#WARNING. This will freeze all of Maple.
timelimit(30,dsolve(ode));
Download maple_lock_up_july_17_2024.mw
These are GUI options on my end.
UPDATE 1
in Maple 2023.2 also on windows 10,  there is no lock up at all. same code. The solution to the ode is very large. I tried using both typesetting level  to EXTENDED  and  typesetting level MAPLE STANDARD and no hang.
I wonder if this has something to do with why Maple 2024.1 locks up? But I have not changed anything in my end. I made no change in options or anything else. same PC, same graphics card.
UPDATE 2
Found the BUG!!
In Maple 2024.1, if I change the display option typesetting level  to EXTENDED, the front end do not hang.
If I change the display typesetting level MAPLE STANDARD, the ftont end hangs.
But why??
Physics:-Version();
interface(typesetting=extended):
`[Length of output exceeds limit of 1000000]`
interface(typesetting=standard):
#WARNING, this will hang MAPLE now. WHY??
Download maple_lock_up_july_17_2024_2.mw
ps. Reported to Maplesoft support. July 17, 2024. Hopefully this will be fixed in Maple 2024.2
