Question: maple hangs when using inert multiplication in RHS of applyrule
I wanted to change  eq:= 1/2 * sqrt(-2*lambda)  to 1/2 %* sqrt(-2*lambda)  using a rule.
It works outside of rule ofcourse. But when I put %* in the RHS of the rule, maple hangs. It seems it is going into infinite loop.
I tried the trick of using '%*' but this gives syntax error.
Same problem happens when using %. and not just %*
Is there a workaround?
Attached worksheet. Make sure to save all work before trying it.
Physics:-Version()
`The "Physics Updates" version in the MapleCloud is 1804. The version installed in this computer is 1802 created 2024, September 3, 11:35 hours Pacific Time, found in the directory C:\Users\Owner\maple\toolbox\2024\Physics Updates\lib\`
libname;
"C:\Users\Owner\maple\toolbox\2024\Physics Updates\lib", "C:\Program Files\Maple 2024\lib"
(1/2)*(-2*lambda)^(1/2)
eq:= 1/2 %. sqrt(-2*lambda); #no problem
`%.`(1/2, (-2*lambda)^(1/2))
eq:= 1/2 %* sqrt(-2*lambda); #no problem
`%*`(1/2, (-2*lambda)^(1/2))
applyrule(sqrt(x::anything)/y::anything = 1/y %. sqrt(x),eq); #why this hangs?
applyrule(sqrt(x::anything)/y::anything = 1/y %* sqrt(x),eq); #why this hangs?
Download maples_hangs_applyrule_sept_10_2024.mw
