Question: combine plottools shapes using display. How to make top shape hide shape below it?
I wanted to draw vertical line (as y axis) and add a solid disk at some y location (to indicate some point location). I used plottools:-disk  to make the small disk and used plottools:-line to make the y-axis then used plots:-display to combine them.
All is ok, except the disk is transparent. i.e. I can see the y-axis line below it. Is there a way to make it not transparent? i.e. solid color, so that the y-axis below it do not show?
#plot vertical line
L:=plottools:-line([0,0],[0,3],color="blue"):
c1:=plottools:-disk([0,1],.1,color="red"):
c2:=plottools:-disk([0,2],.1,color="green"):
plots:-display([L,c1,c2],scaling=constrained,axes=none)
i.e.
Download plotools_nov_9_2024.mw
