Question: why patmatch(1, (x::anything)^(n::'nonunit'(anything))) gives true?
I am learning patten matching in Maple.
Any one could explain why patmatch(1, (x::anything)^(n::'nonunit'(anything)))   gives true but patmatch(2, (x::anything)^n::'nonunit'(anything)); gives false?
true
false
Download patmatch_question_nov_16_2024.mw
I was expecting result similar to using this other software
I do not understand Maple's result. How could I change the patmatch so it does not match 1 to the pattern x::anything^n::anything where n is not 1 ?
Update
To give context, I was trying to write this example from the other software  in Maple:
But when I wrote this
expr:=1 + x^2 + x^4;
F:=proc(X::anything,x::symbol)
    local la,y,n;
    if patmatch(X, (y::anything)^(n::'nonunit'(anything)) ,'la') then
       f(eval(n,la));
     else
        X;
     fi;
end proc;
map(X->F(X,x), expr);
Maple gave
So I modified the code now to check for explicit 1,  to avoid this bad match, like this
    local la,y,n;
        if eval(y,la)=1 then #bug in maple?
           X;
        else
           f(eval(n,la));
        fi;
     else
        X;
     fi;
end proc;
And now it gives expected result
