Question: bug report: Maple dsolve throws internal error on invalid IC
THis IC for Abel ode is not valid and should result in no solution. But instead of returning NULL, dsolve throws internal error called Error, (in dsolve) invalid limiting point
Physics:-Version();
`The "Physics Updates" version in the MapleCloud is 1844 and is the same as the version installed in this computer, created 2025, January 25, 22:5 hours Pacific Time.`
ode:=diff(y(x),x)-x^a*y(x)^3+3*y(x)^2-x^(-a)*y(x)-x^(-2*a)+a*x^(-a-1) = 0;
diff(y(x), x)-x^a*y(x)^3+3*y(x)^2-x^(-a)*y(x)-x^(-2*a)+a*x^(-a-1) = 0
DEtools:-odeadvisor(ode);
sol:=dsolve([ode,y(1)=1])
[_Abel]
tracelast;
 dsolve called with arguments: [diff(y(x), x)-x^a*y(x)^3+3*y(x)^2-x^(-a)*y(x)-x^(-2*a)+a*x^(-a-1) = 0, y(1) = 1], arbitraryconstants = subscripted, atomizenames = true, build = false, numeric = false, type = none
 #(dsolve,80): error
 \`dsolve/IC\` called with arguments: [diff(y(x), x)-x^a*y(x)^3+3*y(x)^2-x^(-a)*y(x)-x^(-2*a)+a*x^(-a-1) = 0, y(1) = 1], {y(x)}, skipimplicit = false, skippparticularsolforlinearODEs = true, solution = {}, usesolutions = particular and general
 #(\`dsolve/IC\`,64): draft := procname(_passed,':-usesolutions = "general"');
 \`dsolve/IC\` called with arguments: [diff(y(x), x)-x^a*y(x)^3+3*y(x)^2-x^(-a)*y(x)-x^(-2*a)+a*x^(-a-1) = 0, y(1) = 1], {y(x)}, skipimplicit = false, skippparticularsolforlinearODEs = true, solution = {}, usesolutions = general
 #(\`dsolve/IC\`,277): zz := map(op,{\`dsolve/IC/_C\`({ANS[i]},funcs,x,ics)});
 \`dsolve/IC/_C\` called with arguments: {y(x) = -exp(2*x^(-a+1)/(a-1))/(_C[1]-2*2^(2*(a+1)/(a-1))*(1/(-a+1))^((a+1)/(a-1))*(2^(-(5*a-3)/(a-1))*(1/(-a+1))^(-(a+1)/(a-1))*x^(2*a)*(-a+1)^2*(x^(-a+1)/(-a+1))^(1/(a-1))*(-4*x^(-a+1)*a^2/(-a+1)+8*a*x^(-a+1)/(-a+1)-4*x^(-a+1)/(-a+1)+2*a-2)*WhittakerM(-(a+1)/(a-1)+1/(a-1), -1/(a-1)+1/2, 4*x^(-a+1)/(-a+1))*exp(-2*x^(-a+1)/(-a+1))/((a+1)*(-3+a))-2^(-(3*a-1)/(a-1))*(1/(-a+1))^(-(a+1)/(a-1))*x^(2*a)*WhittakerM(-(a+1)/(a-1)+1/(a-1)+1, -1/(a-1)+1/2, 4*x^(-a+1)/(-a+1))*(-a+1)^2*(x^(-a+1)/(-a+1))^(1/(a-1))*exp(-2*x^(-a+1)/(-a+1))/((a+1)*(-3+a)))/(-a+1))^(1/2)+x^(-a)}, {y(x)}, x, [y(1) = 1]
 #(\`dsolve/IC/_C\`,1): ans := \`dsolve/IC/_C/do\`(solns,depvars,t,inits,'evaluated_ans', "default",':-giveup = giveup');
 \`dsolve/IC/_C/do\` called with arguments: {y(x) = -exp(2*x^(-a+1)/(a-1))/(_C[1]-2*2^(2*(a+1)/(a-1))*(1/(-a+1))^((a+1)/(a-1))*(2^(-(5*a-3)/(a-1))*(1/(-a+1))^(-(a+1)/(a-1))*x^(2*a)*(-a+1)^2*(x^(-a+1)/(-a+1))^(1/(a-1))*(-4*x^(-a+1)*a^2/(-a+1)+8*a*x^(-a+1)/(-a+1)-4*x^(-a+1)/(-a+1)+2*a-2)*WhittakerM(-(a+1)/(a-1)+1/(a-1), -1/(a-1)+1/2, 4*x^(-a+1)/(-a+1))*exp(-2*x^(-a+1)/(-a+1))/((a+1)*(-3+a))-2^(-(3*a-1)/(a-1))*(1/(-a+1))^(-(a+1)/(a-1))*x^(2*a)*WhittakerM(-(a+1)/(a-1)+1/(a-1)+1, -1/(a-1)+1/2, 4*x^(-a+1)/(-a+1))*(-a+1)^2*(x^(-a+1)/(-a+1))^(1/(a-1))*exp(-2*x^(-a+1)/(-a+1))/((a+1)*(-3+a)))/(-a+1))^(1/2)+x^(-a)}, {y(x)}, x, [y(1) = 1], evaluated_ans, default, giveup = giveup, usecansolve = false
 #(\`dsolve/IC/_C/do\`,133): Solns := map((u, S) -> map(limit,S,op(u)),csol,Solns);
 limit called with arguments: y(x) = -exp(2*x^(-a+1)/(a-1))/(_C[1]-2*2^(2*(a+1)/(a-1))*(1/(-a+1))^((a+1)/(a-1))*(2^(-(5*a-3)/(a-1))*(1/(-a+1))^(-(a+1)/(a-1))*x^(2*a)*(-a+1)^2*(x^(-a+1)/(-a+1))^(1/(a-1))*(-4*x^(-a+1)*a^2/(-a+1)+8*a*x^(-a+1)/(-a+1)-4*x^(-a+1)/(-a+1)+2*a-2)*WhittakerM(-(a+1)/(a-1)+1/(a-1), -1/(a-1)+1/2, 4*x^(-a+1)/(-a+1))*exp(-2*x^(-a+1)/(-a+1))/((a+1)*(-3+a))-2^(-(3*a-1)/(a-1))*(1/(-a+1))^(-(a+1)/(a-1))*x^(2*a)*WhittakerM(-(a+1)/(a-1)+1/(a-1)+1, -1/(a-1)+1/2, 4*x^(-a+1)/(-a+1))*(-a+1)^2*(x^(-a+1)/(-a+1))^(1/(a-1))*exp(-2*x^(-a+1)/(-a+1))/((a+1)*(-3+a)))/(-a+1))^(1/2)+x^(-a), _C[1] = exp((4*I)*Im(1/(a-1)))*infinity, parametric = false
 #(limit,2): return map(thisproc,_passed)
 limit called with arguments: y(x), _C[1] = exp((4*I)*Im(1/(a-1)))*infinity, parametric = false
 #(limit,33): error "invalid limiting point"
 locals defined as: ddir = ddir, dexpr = y(x), fexpr = fexpr, r = r, x = _C[1], fL = fL, L = exp((4*I)*Im(1/(a-1)))*infinity, efloat = efloat, lfloat = lfloat, ind_dexpr = ind_dexpr, ind_L = ind_L, lexpr = lexpr, t = t, limr = limr, liml = liml, pt = (_C[1] = exp((4*I)*Im(1/(a-1)))*infinity), inertfunctions = {}, limitX = limitX, parameters = parameters, Y = Y, limc = limc, cexpr = cexpr, texpr = texpr, bexpr = bexpr, limt = limt, limb = limb, param = param, c = c, N = N, Z = Z, P = P, o = o, e = e, uneval = uneval, i = i, A = A, cond = cond, ll = ll, rr = rr
Download internal_error_instead_of_no_solution.mw
