Question: bug report. dsolve sometimes gives series solution without the O(x^n) term
The series to ode using 'series' option (if it exists) should always be series(...), i.e. with big O at end. but sometimes Maple forgets to add this. Here is an example
`Standard Worksheet Interface, Maple 2025.0, Linux, March 24 2025 Build ID 1909157`
Physics:-Version();
`The "Physics Updates" version in the MapleCloud is 1862 and is the same as the version installed in this computer, created 2025, April 25, 10:33 hours Pacific Time.`
SupportTools:-Version();
`The Customer Support Updates version in the MapleCloud is 15 and is the same as the version installed in this computer, created April 27, 2025, 23:18 hours Eastern Time.`
ode:=diff(y(x),x)+y(x)=1+x;
IC:=y(0)=0;
sol:=dsolve([ode,IC],y(x),'series')
diff(y(x), x)+y(x) = 1+x
y(0) = 0
y(x) = x
lprint(sol); # notice solution is not series, it should be
y(x) = x
#above solution should be
y(x) = series(x+O(x^6),x,6)
#this example below is correct
IC:=y(0)=1;
y(0) = 1
y(x) = series(1+(1/2)*x^2-(1/6)*x^3+(1/24)*x^4-(1/120)*x^5+O(x^6),x,6)
lprint(sol); #solution is series
y(x) = series(1+1/2*x^2-1/6*x^3+1/24*x^4-1/120*x^5+O(x^6),x,6)
Download bug_report_dsolve_series_april_28_2025.mw
