Question: Describe function in procedure
Hello, I have a procedure "timing" in the code editor that I am calling from the main canvas of a flow document. I would like to print the procedure description text string from the Description option in the procedure using the Describe command. However, Describe(timing) does not return anything.
The flow document is at this link: Procedure-Describe.flow
I would appreciate any suggestions.
