Question: How can I plot a bifurcation diagram?
I'm working on a system of coupled ordinary differential equations with multiple degrees of freedom. I would like to explore the existence of multiple solutions by using a bifurcation diagram. To this end, I tried using the built-in Bifurcation command in Maple. However, the command repeatedly returns errors and fails to produce the expected plots.
Has anyone successfully used the Bifurcation command in Maple for coupled ODE systems? Are there specific settings or prerequisites that I might be missing? I would greatly appreciate any guidance or example code demonstrating how to properly use this command for such systems.
bifurcation.mw
