Question: how to use overload for an object method?
I can't figure the correct syntax for using overloaded proc name as an exported method for an object. Maple gives
Error, static procedure `person:-set_name` refers to non-static local or export `person:-_name::string` in surrounding scope
Tried different places of where to put the ::static spec but none worked.
Here is a version which does not use overload which works. But I wanted to merge the two procs called set_name_one() and set_name_two() shown below into one called set_name().
module person()
  option object;
  local _name::string;
  export ModuleCopy::static := proc(_self,proto::person,the_name::string)
        _name:=the_name;
  end proc;
  export set_name_two::static:= proc(_self,first_name::string,last_name::string,$)
       print("in proc which takes two arguments");
       _name:=cat(first_name," ",last_name);
  end proc;
  export set_name_one::static:= proc(_self,the_name::string,$)
       print("in proc which takes one argument");
       _name:=the_name;
  end proc;
  export get_name::static:=proc(_self,$)
        _name;
  end proc;
end module;
module person () local _name::string; option object; end module
o:=Object(person,"me")
o:-set_name_two("me","joe");
"me joe"
o:-set_name_one("me");
"me"
Download working_version_OOP_nov_1_2025.mw
This below now uses overload. It seems inside the overloaded proc, one can't refere to _self local methods such as _name in this example?
`Standard Worksheet Interface, Maple 2025.1, Linux, June 12 2025 Build ID 1932578`
module person()
  option object;
        _name:=the_name;
    end proc;
    export set_name::static := overload(
             proc(_self,first_name::string,last_name::string,$) option overload;
                last_name;
            end,
            proc(_self,the_name::string,$) option overload;
                  _name:=the_name;
            end
        _name;
    end proc;
end module;
Download overload_in_OOP_nov_1_2025.mw
Next, I tried without using static:: on the overload. Now the initial error is gone, But the method call to set_name() gives an error. (see below)
Is there something I am doing wrong? Or overload does not work for object methods? Is there a workaround?
module person()
  option object;
        _name:=the_name;
    end proc;
    export set_name := overload(
                last_name;
            end,
                  _name:=the_name;
            end
        _name;
    end proc;
end module;
module person () local _name::string; export set_name; option object; end module
o:-set_name("me");
Error, invalid input: no implementation of set_name matches the arguments in call, 'set_name("me")'
Download overload_in_OOP_nov_1_2025_V2.mw
Here is another version where static:: is kept on the overload, but now code changed to use _self:-_name to refer to the private object variable instead of just _name (even though this is not needed). Now the initial error is gone, but now calling object:-set_name("me") result in new error Error, (in person:-set_name) `me` does not evaluate to a module
module person()
  option object;
        _name:=the_name;
    end proc;
                last_name;
                _self:-_name:=cat(first_name," ",last_name);
            end,
                  _self:-_name:=the_name;
            end
        _name;
    end proc;
end module;
o:-set_name("me");
Download overload_in_OOP_nov_1_2025_V3.mw
I am starting to think overload does not work for object procs but only for standard procs or for standard module procs which is does not have option object;  That will be too bad.
I wonder if there is alternative to overload for Maple object if this was the case.
