Question: symgen order does not match trace information
Solving this ode, Maple says
But notice, the xi and eta tangent vectors order is reversed. Maple says pattern is [0,F*G], but shows [F*G,0].
Also, when later using DEtools:-symgen with HINT option, it does not return the above result. Tried both patterns with 0 on left and 0 on right. In both cases symgen does not return what shows above.
Why is that? Am I doing something wrong? Notice also it says   "way=HINT"  but I am not using way option. Only HINT option, Why is it saying way=HINT? it seems argument passing I  am using is wrong, but do not see why it could be wrong.  This is what help says
Worksheet below
`Standard Worksheet Interface, Maple 2025.2, Windows 10, November 11 2025 Build ID 1971053`
ode:=diff(y(x),x)*cos(y(x))-cos(x)*sin(y(x))^2-sin(y(x)) = 0;
infolevel[dsolve]:=5;
infolevel[symgen]:=5;
(diff(y(x), x))*cos(y(x))-cos(x)*sin(y(x))^2-sin(y(x)) = 0
5
5
dsolve(ode);
Methods for first order ODEs:
--- Trying classification methods ---
trying a quadrature
trying 1st order linear
trying Bernoulli
trying separable
trying inverse linear
trying homogeneous types:
trying Chini
differential order: 1; looking for linear symmetries
trying exact
Looking for potential symmetries
trying inverse_Riccati
trying an equivalence to an Abel ODE
differential order: 1; trying a linearization to 2nd order
--- trying a change of variables {x -> y(x), y(x) -> x}
trying 1st order ODE linearizable_by_differentiation
--- Trying Lie symmetry methods, 1st order ---
 -> Computing symmetries using: way = 3
 -> Computing symmetries using: way = 4
 -> Computing symmetries using: way = 5
trying symmetry patterns for 1st order ODEs
 -> Computing symmetries using: way = patterns
-> trying a symmetry pattern of the form [F(x)*G(y), 0]
-> trying a symmetry pattern of the form [0, F(x)*G(y)]
-> The symmetry found is [0 exp(-x)*(2*sin(y)^2+cos(y)^2-1)/cos(y)]
<- symmetry pattern of the form [0, F(x)*G(y)] successful
[exp(-x)*(2*sin(y)^2+cos(y)^2-1)/cos(y), 0]
 <- successful computation of symmetries.
y(x) = arctan(-2*exp(x)/(exp(x)*cos(x)+exp(x)*sin(x)+2*c__1), ((2*cos(x)*sin(x)*(exp(x))^2+4*c__1*sin(x)*exp(x)+4*cos(x)*c__1*exp(x)+4*c__1^2+(exp(x))^2)*(2*cos(x)*sin(x)*(exp(x))^2+4*c__1*sin(x)*exp(x)+4*cos(x)*c__1*exp(x)-3*(exp(x))^2+4*c__1^2))^(1/2)/(2*cos(x)*sin(x)*(exp(x))^2+4*c__1*sin(x)*exp(x)+4*cos(x)*c__1*exp(x)+4*c__1^2+(exp(x))^2)), y(x) = arctan(-2*exp(x)/(exp(x)*cos(x)+exp(x)*sin(x)+2*c__1), -((2*cos(x)*sin(x)*(exp(x))^2+4*c__1*sin(x)*exp(x)+4*cos(x)*c__1*exp(x)+4*c__1^2+(exp(x))^2)*(2*cos(x)*sin(x)*(exp(x))^2+4*c__1*sin(x)*exp(x)+4*cos(x)*c__1*exp(x)-3*(exp(x))^2+4*c__1^2))^(1/2)/(2*cos(x)*sin(x)*(exp(x))^2+4*c__1*sin(x)*exp(x)+4*cos(x)*c__1*exp(x)+4*c__1^2+(exp(x))^2))
infolevel[dsolve]:=0;
0
DEtools:-symgen(ode,y(x),HINT = [ 0,F(x)*G(y)]); #why this does not return the symmetries found by dsolve above?
 -> Computing symmetries using: way = HINT
DEtools:-symgen(ode,y(x),HINT = [ F(x)*G(y),0]); #why this does not return the symmetries found by dsolve above?
DEtools:-symgen(ode)
 -> Computing symmetries using: way = 2
 -> Computing symmetries using: way = abaco1
[0, exp(-x)*(-1+cos(2*y))/cos(y)]
[_xi = 0, _eta = exp(-x)*(-1+cos(2*y))/cos(y)]
Download symgen_confusion_jan_9_2026.mw
