Question: Wrong root of sinc expression
Here is another case where an incorrect solution of a non-algebraic expression is returned.
How to make Maple exclude solutions obtained with allsolutions where the expression is not defined?
IMO, allsolutions facilities of Maple should do this automatically. Anything from a mathematical point of view that speaks against an automatic exclusion?
(Are there other commands that provide a correct solution?)
By the way:
solve(sin(x)/x)
does not return a single solution as stated on the solve help page ("In general for transcendental equations, the solve command returns only one solution,...") because solve correctly discards x=0 but does not consider returning x=pi.
expr := sin(x)/x
sin(x)/x
The above expression is not defined at x = 0
Eval(expr, x = 0)
Eval(sin(x)/x, x = 0)
value(Eval(sin(x)/x, x = 0))
Error, (in value/Eval) numeric exception: division by zero
Roots of the expression with RootOf
sol := allvalues(RootOf(expr))
Pi*_Z1
indets(sol)
{_Z1}
about({_Z1}[])
Originally _Z1, renamed _Z1~:
  is assumed to be: integer
getassumptions({_Z1})
{_Z1::integer}
type(0, integer)
true
subs(x = sol, expr) = 0
sin(Pi*_Z1)/(Pi*_Z1) = 0
is(sin(Pi*_Z1)/(Pi*_Z1) = 0)
true
The above should be false because expr is not defined for _Z1 = 0.However, this is what automatic simplifcation does behind the scenes with the output (7)
0 = 0
For this particular case Maple should have returned a special name expressing nonzero integers, like _NZ .
`ℤ__≠0`or `minus`(integer, {0})or `#msup(mi("ℤ",fontstyle = "normal"),mo("*"))`are common symbols for that
So _Zis incorrect in the solution and automatic simplification does something wrong.
Only substituing everything at once leads to a correct response:
subs(x = sol, _Z1 = 0, expr)
Error, numeric exception: division by zero
Solve
solve(expr, x)
x_sol := [solve(expr, x, allsolutions)]
[2*Pi*_Z2, Pi*(2*_Z2+1)]
indets(x_sol)
{_Z2}
subs(x = x_sol[1], expr) = 0
(1/2)*sin(2*Pi*_Z2)/(Pi*_Z2) = 0
is((1/2)*sin(2*Pi*_Z2)/(Pi*_Z2) = 0)
true
0 = 0
(14)
subs(x = x_sol[1], _Z2 = 0, expr) = 0
Again _Z2 = 0is not a valid solution for the first solution butNULLworks for the second solution
subs(x = x_sol[2], expr) = 0
sin(Pi*(2*_Z2+1))/(Pi*(2*_Z2+1)) = 0
(15)
is(sin(Pi*(2*_Z2+1))/(Pi*(2*_Z2+1)) = 0)
true
(16)
0 = 0
(17)
Substituing everything at once works
subs(x = x_sol[2], _Z2 = 0, expr) = 0
sin(Pi)/Pi = 0
(18)
sin(Pi)/Pi = 0
0 = 0
(19)
However, the second solution does not cover all solutions (it misses even multiples of π)
[seq({_Z2}[] = i, i = -2 .. 2)]
[_Z2 = -2, _Z2 = -1, _Z2 = 0, _Z2 = 1, _Z2 = 2]
(20)
seq(subs([_Z2 = -2, _Z2 = -1, _Z2 = 0, _Z2 = 1, _Z2 = 2][i], x_sol[2]), i = 1 .. nops([_Z2 = -2, _Z2 = -1, _Z2 = 0, _Z2 = 1, _Z2 = 2]))
-3*Pi, -Pi, Pi, 3*Pi, 5*Pi
(21)
Related topic: I also think that new users and students should profit from a directly understandable output like this
Maybe adding new convert form is an option.
Download roots_of_sinc.mw
