Question: Problem with iterative process
I have a similar problem to a previous problem of mine. I want to put an iterative process inside an iterative process. I have reduced the a PDE to the fourth order ODE below
F’’’’(η)+αη F’’’(η)+2α F’’(η)-R(F’(η)F’’(η)-F(η) F’’’(η))=0                                   (1)
With boundary conditions
F(1)=1, F(-1)=-1,F’(1)=0,F’(-1)=0
I want to use a small-R approximation F=∑n=0RFnto equate powers of R. Using this substitution I get for R:
F0’’’’(η)+αη F0’’’(η)+2α F0’’(η)=0        (2)
I then want to go on to substitute a small-α approximation F0=∑n=0αF0n. Equating powers of α now I get
F00’’’’=0 with boundary conditions
F00(1)=1, F00(-1)=-1,F00’(1)=0,F00’(-1)=0
Which can be solved and used again when solving the equation corresponding to the coefficients of α. I want to keep iterating the process using equation (2) and the small-α approximation. So I will have an equation for F0 using F0=∑n=0αF0n. I want to go back to look at the equation corresponding to the coefficients of R in the small R expansion. Which is
F1’’’’(η)+αη F0’’’(η)+2α F0’’(η)-F0’F0’’-F0F0’’’=0
Again apply the small α approximation to get for α
F10’’’’-F00’’F00’’-F00F00’’’=0
Boundary conditions: F10(1)=0, F10(-1)=0,F10’(1)=0,F10’(-1)=0
But I will have calculated F00 already so I want to repeat the process eventually getting an equation for F using F=∑n=0RFn.
I have tried to adapt some of the code from an old post of mine but I don’t know where to go with it. I’m not very experienced with maple but the nature of this problem means i cannot keep doing this by hand. It’s driving me crazy!
Here is the code
> restart;
> with(plots);
> with(LinearAlgebra);
 > nmax:=30:
> Order:=nmax+1:
> de1:=diff(F(eta,alpha),eta$4)+alpha*eta*diff(F(eta,alpha),eta$3)+2*alpha*diff(F(eta,alpha),eta$2);
> S1:=series(eval(de1,F(eta,alpha)=add(F[k](eta)*alpha^k,k=0..nmax)),alpha):
> des1:=[seq(coeff(S1,alpha,k),k=0..nmax)]:
> bcs:=k->(F[k](-1)=`if`(k=0,-1,0),F[k](1)=`if`(k=0,1,0),D(F[k])(-1)=0,D(F[k])(1)=0);
> for k from 1 to nmax+1 do
      gsol:=unapply(rhs(dsolve(des1[k],useint)), eta):
      F[k-1]:=subs(solve(eval({bcs(k-1)},F[k-1]=gsol)),eval(gsol));
end do:
This just goes through the small-α approximation for equation (2) 30 times.
Any help would be greatly appreciated.
