Question: The order of variables in an answer
Is there a way for maple to display an answer with a set order?  or set it so it always does it a certain way.
As an example, lets take eq1:=a=(v-vo)/t then solve(eq1,{v});  (I put the v in {} so the answer will display the full equation).  Without the {} it only displays the answer.  Anyways, the answer returned is {v=a*t+vo}
I would like to manipulate it so that maple will always display an equation with a single variable first.  So, for in our example I would like it shown as  v=vo+a*t
I know maple can sort based on the powers of a variable, but what about the number of variables?  There is also a similar issue where answers pop out that have the negative sign out front instead of multiplying it through and rearranging the equation to look "proper" so to speak.
This has been branched into the following page(s):
