Question: Linux directory change
I have a Maple code which I wrote on a Windows machine. Now I need to run it on a Linux machine. I set the directory by the command
currentdir("C:/example"):
How should I change this if I want it to be /home/user/example ?
and I use
fopen("C:/mydir/examp/example.dat", WRITE):
How should I change this line in Linux if I want it to be in /usr/local/mydir/examp/example.dat?
Are there any other changes should I make to convert my code to Linux? These above ones are the only ones which deal with the file system, the rest are usual Maple commands.
Thank you in advance.
