Question: why is the loop counter assigned?
One thing I think is a bit strange is the notion that the loop counter
is assigned a value after the loop is done. Why is that ?
for example:
for i to 10 do
print(i)
end do;
The above code will simply print 1..10 but then if you simply run:
i;
then 11 will be printed out. How often do you actually need i to be assigned
a value after the loop is done?
I think it would have been much better if i is unassigned when the loop is done
othewise it can create problems for the user later on if he does not realise that
i is already asigned a value.
