Question: Thanks, and how can I make and use functions f( c[n](t) ) of the basic output c[n](t) of dsolve/numeric, e.g. norm = add(abs(c[n](t))^2,n=1..nn) ?
# Maple15\xsys14demo.mw, Maplesoft, standard worksheet, BoltzQM, Shift & enter, ADD not SUM, 1-D math for procedure
with(StringTools):
FormatTime(%c);
with(DEtools):
printlevel := 1:
mm := 3:
nn := 3:
a := 5.:
e := 1.:
R := .1:
h := 1.:
t2:=5:
Δt:=t2/10:
dproc3 := proc (nn, t, Y, YP)
local n, nd, md;
   for n to nn do
      YP[n] := -((I*e^2*4)/(h*a^2))*Y[n]*add(add(Y[nd]*conjugate(Y[nd])
          *evalf[11](Int(sin(Pi*n*x/a)*sin(Pi*nd*x/a)*sin(Pi*n*y/a)*sin(Pi*nd*y/a)/sqrt((x-y)^2+4*R^2*sin(Pi*md/mm)^2),
           [y = 0. .. a, x = 0. .. a])), md = 1 .. mm-1), nd = 1 .. nn);
   end do;
end proc;
ic3 := array([seq(((1-I)/sqrt(2))/sqrt(nn), n = 1 .. nn)]):
dvars3 := [seq(c[n](t), n = 1 .. nn)]:
tt := time():
p := dsolve(type=numeric, number = nn, procedure = dproc3, start = 0., initial = ic3, procvars = dvars3,
     range=0..t2+Δt, method=rkf45);
p(3);
p(3)[2];
p[2](3);
evalf[11](add(abs(c[n](3))^2,n=1..nn)); (* norm, not evaluated error *)
#abs(evalf[11](p(3)[2]));
#Int(2.*ln(abs(p[3](t))), t = 5. .. 5.5000000000);
`Solver time = `,time()-tt;
FormatTime(%c);
tt := time():
display([seq(odeplot(p,[t,ln(abs(c[n](t))^2)]),n=1 .. nn)]);
display([seq(odeplot(p,[t,evalf[11](Int(ln(abs(c[n](td))^2),td= t..t+Δt))]),n=1 .. nn)]); (* running average, error message*)
evalf[11](Int(ln(abs(c[3](t))^2),t= t2..t2+Δt));
`Plotting time = `,time()-tt;
proc (nn, t, Y, YP) local n, nd, md; for n to nn do YP[n] := -(4*I)*e^2*Y[n]*add(add(Y[nd]*conjugate(Y[nd])*evalf[11](Int(sin(Pi*n*x/a)*sin(Pi*nd*x/a)*sin(Pi*n*y/a)*sin(Pi*nd*y/a)/sqrt((x-y)^2+4*R^2*sin(Pi*md/mm)^2), [y = 0. .. a, x = 0. .. a])), md = 1 .. mm-1), nd = 1 .. nn)/(h*a^2) end do end proc
`Non-fatal error while reading data from kernel.`
[t = 3., c[1](t) = .545625535022993-.188748293170450*I, c[2](t) = .576328988879470-0.343226702270833e-1*I, c[3](t) = .524540126942242+.241227739747382*I]
abs(c[1](3))^2+abs(c[2](3))^2+abs(c[3](3))^2
`Solver time = `, 3.853
Error, (in plots/odeplot) curve is not fully specified in terms of the ODE solution, found additional unknowns {td, c[1](td)}
Int(2.*ln(abs(c[3](t))), t = 5. .. 5.5000000000)
`Plotting time = `, .921
Download xsys14demo.mw
I enclose xsys14demo.nb which, thanks to the prompt and expert help from you, is the 'fast' version of my original 'slow' xsys11demo.nb. I now wish to make and use functions   f( c[n](t) ) of the basic output c[n](t) of dsolve/numeric, e.g. the norm = add(abs(c[n](t))^2,n=1..nn) ? The _14_.nb show some attempts and error messages or, 'non numeric' results.
How do I do this? It must be very basic and very used Maple, and I have made and honest attempt to understand via Maple Help etc. In particular I want a running average of my Boltzmann probability = (1)/(Delta)(∫)[t]^(t+Deltat)abs(c[n](t'))^(2)ⅆt' in odeplot.
(I have done all this in Mathematica 8, and am now 'learning' Maple 15/16).
I am ashamed I cannot do this basic operation, but unfortunately shame will not solve my problem!
Best Regards,    Michael Caola
