Question: linearsol(ode1, y(x)) return {}
ode1 := Diff(y(x),x$2) + (lambda-x^2)*y(x) = 0;
After put y = exp(-x^2/2)*y1(x) into above ode1
would like to find the solution of ode in terms of integration
in this example, it use z^(-lambda/2-1/2) = expa(-lambda/2-1/2)*log(z)
the example solution should be int(exp(...),z)
linearsol(ode1, y(x)); but return {}  nothing
