Question: Explore command and Classic Worksheet
Greetings!
I only recently started to work with Maple17 and tried to test the Explore command. In Classic worksheet I tried a very simple function with a parameter, but after setting the inteval of the parameter in the Java pop-up window I have no result. In return I take: "Error, (in Explore) invalid input: rtable_dims uses a 1st argument, A (of type rtable), which is missing"
Has anyone encounter the same issue before?
Thanx
