Question: Maple help me please
Hi,
can you please help me solve that?
I want to write maple procedure that checks if a number is prime or not and I need to do it so that it doesn`t take forever to give an answer.
I wrote a procedure that works good with small numbers but when I put bigger numbers eg.9999971 it is taking far too long (5min) to get the answer, I tried to modify it and I think I find out something that could be modified to make it more efficient, like for example in the line:   for j from 2 to n-1 do     (I changed it to: ) for j from 2 to n-1  by n do    - it tooks 9.953 second to get the answer   (or I changed it to: ) for j from 2 to (n-1)/2  do   - it tooks 262.062 second I also tried many things and I always get an answer after long time excepte when I changed the line to for j from 2 to (n-1)/n  do   - it tooks 0 second but I didn't find any explanation why should I devide it by n as j from 2 to ((n-1)/n) = 1-(1/n) which is less than 2 as it make no sence....
But it still not efficient enough, because if for example I use the maple command isprime,then I got the result in less than 1 second.
In the program I used other procedure that I think will make it quicker which is a floor function procedure. please see bellow :
> flr:=proc(a,b)
      local n:
      n:=0:
      while a>=b*(n+1) do
         n:=n+1:
     od:
       n;
   end:
> Isprime:=proc(n)
         local j, p:
         p:=true:
         if n=2 then
            p:=true;
        else
                  if (n/j-flr(n,j))=0 then
                       p:=false:
                  fi:
              od:
         fi:
     p:
     end:
>zeit:=time():
Isprime(9999971);
time()-zeit,`second`;
        true
        309.558, second
Please reply and thank you in advance
