Question: Insert matrices into expressions of quantum operators
Hi again,
I am lost... again. I worked with the Physics package and have obtained my result in form of a lengthy equation of commutators of non-commuting objects. So basically my problem is solved, except that I now want to compute some examples to see, if everything is correct. For that purpose I want to replace now the non-commuting objects with explicit matrices, compute the result and see if it agrees with numerical studies. However, I have no clue which command to use, because if I try it with subs, then the multiplication is of the wrong type and Maple won't multiply my matrices. I tried to use eval but wasn't successful.
Here is an exampe to see what I mean.
Test2.mw
Thank you for your time
NOh
