Question: How to plot 2-D arrows using length and angle?
Hello!
Vectors are defined by a lenth and an angle.
The arrow command wants me to give it a starting point and an endpoint in coordinates, for example:
with(LinearAlgebra);
with(plots);
gu := arrow([5, 10], [15, 20], .2, .4, .1, color = green)
I'm dealing with vectors from electrical circuits, so the information I have would be the lenth of the vector, and an angle given in degrees (which I could convert to radians if needed for the plot).
The goal is to plot all the vectors in the circuit on the same display so that it can be seen how they are in relation to each other, and to visualise the solution. This means I would need to find out the endpoint of the arrows to start the next arrow at that location with its angle in reference to the same axis. Does it make sence? I'm not sure about the wording of this.
Here's a picture of a calculated vector lenth and angle: http://imgur.com/hJtNeGg
So, the -45 degrees would need to be in reference to the y-axis for example, then the next vector can be placed at lets say perpendicular in reference to the vector sol_1, starting at its endpoint.
The only other way I have to draw this, excluding doing it by hand, is using the object tools from microsoft word, and to be honset I dislike using word for math stuff. I would much rather learn the syntax for Maple to do this.
I hope someone knows what I mean, Please ask if somethig is unclear,
Thanks!
