Question: Error in Distribution
Hi,
  I have the following input
with( Statistics ):
a:=2;c:=0.3;
g:= exp(-a*x) + c*a*exp(-a*x);
#f := x -> piecewise( x < 0, 0, x>0, g );
 f :=x -> piecewise( x < 0, 0, x>0, exp(-a*x) + c*a*exp(-a*x));
norm_factor:=int( f(x), x=0..infinity );
print(norm_factor);
randomize():
F := Distribution( PDF = 1/norm_factor*f ):
X := RandomVariable( F ):
N := 20;
S := convert( Sample(X,N), list );
print(`cc`,S[1]);
The code works. However, if I comment out
 , then use
i.e.
 #f :=x -> piecewise( x < 0, 0, x>0, exp(-a*x) + c*a*exp(-a*x));
It is said "
Error, (in Statistics:-Sample) unable to construct the envelopes for _R, try to specify the initial range"
The norm_factors are actually the same for both inputs. What is the reason for the error message?  Suppose I still want to use something like
,how to fix the problem?
Thank you very much
