Question: Use of shortcuts in Maple 2016
In using Maple there are many ways to complete a command on a function. Using shortcuts in the worksheet/document you can enter the command on the line rather than using the drop down menus or clickable math menu.  I would like to see what the shortcut command are for the packages in Maple.  There are so many, I am using the LinearAlgebra package and have seen Dr. Lopez use " ||A||2 to determine the Euclidean Norm of A.  But where does this use get described in the help or examples of other shortcut usage for Maple. I've seen the shortcut commands for Documents in General, but the use of shortcut commands for other packages  don't seem to discuss the usage of such shortcuts.
Is there a document that documents these shortcuts.
