Question: Does mtaylor ignore "assuming"?
I have the following expression (generated by some other procedure):
This does not have a taylor expansion in pV[6] in the general case because the square roots can become negative:
taylor(xpr,pV[6]);
Error, does not have a taylor expansion, try series()
But I can get an expansion by restrictig the range of pV[6]:
taylor(xpr,pV[6]) assuming -0.01<pV[6],pV[6]<0.01;
So far things are perfectly fine. But when I try mtaylor:
mtaylor(xpr,pV[6]) assuming -0.01<pV[6],pV[6]<0.01;
Error, (in assuming) when calling 'mtaylor'. Received: 'does not have a taylor expansion, try series()'
So the assumption seems to be ignored. I can work around this by expanding in pV[6] first, using taylor, and then expanding the result from that using mtaylor (I really also want the expansions in the other pV components; 6 in total although in this example some do not show up). I'll have to convince myself that this work-around gives the correct result but I think it does. However, I don't particularly like it.
I consider this a bug and am tempted to submit an SCR. But before I do that; is there anything obvious I am missing here?
Thanks,
M.D.
PS: This was done using Maple 15. I'll check newer versions later.
mtaylor_assuming.mw
