Question: install error and no error when using cmd to install and no process in task manager
i got this error in window 8 in surface 2  then follow this post and install again still error
https://www.maplesoft.com/support/faqs/detail.aspx?sid=139020
then follow
http://www.maplesoft.com/support/faqs/detail.aspx?sid=32607
then follow and install again same error
http://www.maplesoft.com/support/faqs/detail.aspx?sid=32631
and install again same eror
then i add option -f c:\Program File (x86)\MapleXX in cmd and then no error any more
but no install succeed
where it go, it still not install
then i try again, there is no room enough to install,  hard disk do not have enough space, then i go to c:\Windows\Temp, after deleted file in it, still not enough space
i find
https://www.maplesoft.com/support/install/maple15_install.html
but template do not state how to activate later
how to write this template and how to clear the temp file created by previous failed cmd install method
