Question: Numerical integration hangs
Hello Mapleprime users
I am having an issue with a numerical integration calculation. I have a large(ish) polynomial integrand and need to apply two integrations which I am using the _cuhre method for. See attached the minimum working example file.
Numerical_integration_HF.mw
Firstly some simplifications are done to the integrand and then a basic for loop which calculates the integration for r from 0 to 20 in steps of 0.1. The issue occurs when the loop hits r~2.5 (on my machine, Maple 2015, i5, 16GB ram). Up to that point the calculation is steady with the following stats per point calculated:
memory used=87.59MiB, alloc change=0 bytes, cpu time=3.45s, real time=3.15s, gc time=439.16ms
Then when the calculation gets to ~2.5 it just hangs and will not calculate past it. Any ideas as to what is going on here?
Any help would be appreciated with this issue.
Thank you in advance
Yeti
