Question: How do i Plot Multiple Array/Vector from Datasheet with Time as x-Axis
Hello
I am trying to write my Measuring Data into several Arrays with lengt of rowdim
I was able to extract them from the Datafile and Refering them to separate Vectors
My Code is in the attachemend and the Datafile too.
Insert the txt Path in the Messdaten in definition of A to load it.
I was able to convert the Time from Seconds to Minutes. What i realy want is an x-Axis wich is like hh:mm:ss
and Plot for Example T__1,T__2,T__Scheibe together in one Plot as y Axis and t__Minuten as x Axis
But the
plot([seq([`t__Sekunden`[i],`T__1`[i]],i=1..rowdim,LinearAlgebra[rowdim](`t__Sekunden`))
doesnt work and i also tried others
Thank you for your Help
