Question: how to massive install 100 maple into amazon to do distributed computing or cluster computing?
and how to write this distributed function to run into 100 maple instance?
assume there is a function with two parameter which is the range of array
and the total number of times of calculations is from 1 to 9^(9^2) and divided this range into many range by  each range length 100,000
how can it write the output into a list of length 9^(9^2) ?
will there limit in length of list or result?
and 100 instance of virtual machine may not enough to calculate, how to allocate the next 100,000 calculations to idle instance which finished previous 100,000 calculations?
