Question: Need help with the code
(a) Plot the graph of
                       sin(x)*exp( -x^2)
 for x in the interval [-2,2].
(b) Find to 10 decimal digits the maximum and minimum values of
                         sin(x)*exp( -x^2)
 for x in [-2,2] AND find the corresponding values of x. [So if the maximum occurs at x=a, you should also compute sin(x)*exp( -x^2)   both to 10 digits. Similarly for the minimum. Using unapply to make the expression into a function will be useful here.]
So far I have this for a
> j := exp(-x^2)*sin(x);
> plot(j, x = -2 .. 2);
