Question: Make an invisible Code Edit Region visible
Hello here is a description of my issue:
1. I created a new code edit region
2. i put some code in the code edit region
3. In the context Panel I unchecked the 'visible' setting for the code edit box
When I evaluate the worksheet the code in the code edit region still runs, but I can't figure out how to edit the code in that region. There is not an icon to open the code edit region as there would be had I toggled the 'expand' setting. Furthermore, I can't select the invisible code edit region in order to toggle the 'visible setting'.
How can I make the code edit region visible again?
Thanks for you help
