Question: How do I use Homotopy Perturbation Method to find an analytical solution for Euler-Bernoulli Beam on Pasternak foundation?
Please, I need to use Maple to solve Euler-Bernoulli Beam on Pasternak Foundation using Homotopy Perturbation Method.
The governing equation is
initial conditions are
the boundary condition is
The governing equation represents Euler-Bernoulli beam on a generalized Pasternak viscoelastic foundation under an
arbitrary distributed dynamic load. in which E, I , ρ ,A are the parameters of the beam, representing Young’s modulus of elasticity, moment of inertia, density and area of cross section, respectively. K,C and Gp are spring stiffness, damping coefficient, and shear coefficient of the foundation. Moreover, y(x, t) and F(x, t) are defined as the vertical deflection of the beam and the generic arbitrary dynamic loads, respectively, where the loads distribute along the x-axis and t is time.
I will appreciate anyone who can help me with a Maple solution.
Thank you.
