Question: Transition Matrix
The code is from the book(SDE). I think P.n := evalm( P.(n-1)&*P0) causes the problem. I have never seen this kind of the structure before ( I did some coding with C and Java). Could you explain that? P0, P1, P2,,,, using for n from 1 to 10. Is "." between P and n the dot (period)? Thank you in advance.
N := 2; A := -N; B := N
q := .3; p := .5; sa := .9; sb := .1; r := 1-p-q
with(linalg)
dimP := 2*N+1
P := matrix(dimP, dimP, [`$`(0, dimP*dimP)])
P[1, 1] := sa; P[1, 2] := 1-sa; P[dimP, dimP] := sb; P[dimP, dimP-1] := 1-sb
for i from 2 to dimP-1 do P[i, i-1] := q; P[i, i] := r; P[i, i+1] := p end do
P0 := P
for n to 10 do P.n := evalm(`&*`(P.(n-1), P0)) end do
print(P10)
P10
Download TransitionMatix.mw
