Question: How to optimize with an interpolated function
Hi,
I want to optimize a function f(g(e(x),x))  where g(x) is interpolated and e(x) is not known when the interpolation object is created. I found the intpolation Methods of Maple 2018 very helpful to quickly change the inpterpolation method.
Unfotunately the optimization fails when the interpolation object receives an expression as input.
It works if I just use x. Do you know my the first approach fails?
Is there maybe a way to convert the interpolation object to a piecewise function?
Thank you for your help
# Optimize with Interpolation Object
points :=  <<0.4000|  10.0000>,
            <0.7000|   10.0000>,
            <1.0000|   10.0000>,
            <0.3000|   30.0000>,
            <0.4000|   30.0000>,
            <0.5000|   30.0000>>;
Data := <0617,0767,0220,0444,0692,0789>*0.001;
intmethod := LinearInterpolation;
g := Interpolation[intmethod](points(1..-1,1),Data):
Matrix(6, 2, {(1, 1) = .4000, (1, 2) = 10.0000, (2, 1) = .7000, (2, 2) = 10.0000, (3, 1) = 1.0000, (3, 2) = 10.0000, (4, 1) = .3000, (4, 2) = 30.0000, (5, 1) = .4000, (5, 2) = 30.0000, (6, 1) = .5000, (6, 2) = 30.0000})
Vector[column](%id = 18446884324022199230)
LinearInterpolation
plot(g(x),x=0..1)
e := x/sqrt(2);
(1/2)*x*2^(1/2)
f := 5+g(e)*x^2
"5+(module() ... end module)(module() ... end module,1/2 x sqrt(2)) x^2"
f_simple := 5+g(x)*x^2
"f_simple:=5+[[["a linear interpolation object"],["with 6 points in 1-D"]]](x) x^2"
op_f := Optimization[Minimize](f(x),x=0 .. 1);
Error, (in Optimization:-NLPSolve) non-numeric result encountered
op_f_simple := Optimization[Minimize](f_simple(x),x=0 .. 1);
[HFloat(4.999979117244145), [x = HFloat(0.028901647183245588)]]
Download convert_interpolation_object.mw
