Question: How do I sort a formula in the following form
Hello,
I want to sort the formulae to Psi and Beta, but I don't know how it works. I have tried it with sort, simplify, isolate, but that isn't what I'm searching.
It should looks like the simplier formula in the picture.
ab := (diff(Psii(t), t, t))*J-l[f]*(F[s, f, l]+F[s, f, r])+l[r]*(F[s, r, l]+F[s, r, r])-(1/2)*b[r]*(-F[s, r, l]*delta[l]+F[s, r, r]*delta[r]) = 0;
  / d  / d         \\
  |--- |--- Psii(t)|| J - l[f] (F[s, f, l] + F[s, f, r])
  \ dt \ dt        //
     + l[r] (F[s, r, l] + F[s, r, r])
     - - b[r] (-F[s, r, l] delta[l] + F[s, r, r] delta[r]) = 0
       2
bc := (diff(betaa(t), t, t))*m*v*betaa(t)+F[s, r, l]*delta[l]+F[s, r, r]*delta[r]-(diff(Psii(t), t)) = 0;
    / d  / d          \\
    |--- |--- betaa(t)|| m v betaa(t) + F[s, r, l] delta[l]
    \ dt \ dt         //
                               / d         \
       + F[s, r, r] delta[r] - |--- Psii(t)| = 0
                               \ dt        /
cd := (diff(betaa(t), t))*m*v+F[s, r, l]+F[s, r, r]+F[s, f, l]+F[s, f, r]-(diff(Psii(t), t)) = 0;
   / d          \
   |--- betaa(t)| m v + F[s, r, l] + F[s, r, r] + F[s, f, l]
   \ dt         /
                     / d         \
      + F[s, f, r] - |--- Psii(t)| = 0
                     \ dt        /
F[s, f, l] := c[fl]*alpha[fl];
                        c[fl] alpha[fl]
F[s, f, r] := c[fr]*alpha[fr];
                        c[fr] alpha[fr]
F[s, r, l] := c[rl]*alpha[rl];
                        c[rl] alpha[rl]
F[s, r, r] := c[rr]*alpha[rr];
                        c[rr] alpha[rr]
alpha[fl] := (-v*betaa-l[f]*(diff(Psii(t), t)))/(-v+(1/2)*b[f]*(diff(Psii(t), t)));
                                 / d         \
                 -v betaa - l[f] |--- Psii(t)|
                                 \ dt        /
                        1      / d         \
                   -v + - b[f] |--- Psii(t)|
                        2      \ dt        /
alpha[fr] := (-v*betaa-l[f]*(diff(Psii(t), t)))/(v-(1/2)*b[f]*(diff(Psii(t), t)));
                                 / d         \
                                 \ dt        /
                       1      / d         \
                   v - - b[f] |--- Psii(t)|
                       2      \ dt        /
alpha[rl] := delta[l]+(-v*betaa+l[r]*(diff(Psii(t), t)))/(-v+(1/2)*b[r]*(diff(Psii(t), t)));
                                       / d         \
                       -v betaa + l[r] |--- Psii(t)|
                                       \ dt        /
            delta[l] + -----------------------------
                              1      / d         \
                         -v + - b[r] |--- Psii(t)|
                              2      \ dt        /
alpha[rr] := delta[r]+(-v*betaa+l[r]*(diff(Psii(t), t)))/(-v-(1/2)*b[r]*(diff(Psii(t), t)));
                                       / d         \
                                       \ dt        /
            delta[r] + -----------------------------
                              1      / d         \
                         -v - - b[r] |--- Psii(t)|
                              2      \ dt        /
ab;
/ d  / d         \\          |
|--- |--- Psii(t)|| J - l[f] |
\ dt \ dt        //          |
        /                / d         \\
  c[fl] |-v betaa - l[f] |--- Psii(t)||
        \                \ dt        //
             1      / d         \
             2      \ dt        /
           /                / d         \\\        /      /
     c[fr] |-v betaa - l[f] |--- Psii(t)|||        |      |
           \                \ dt        //|        |      |
   + -------------------------------------| + l[r] |c[rl] |delta[
               1      / d         \       |        |      |
           v - - b[f] |--- Psii(t)|       |        |      |
               2      \ dt        /       /        \      \
                       / d         \\
       -v betaa + l[r] |--- Psii(t)||
                       \ dt        /|
  l] + -----------------------------|
              1      / d         \  |
         -v + - b[r] |--- Psii(t)|  |
              2      \ dt        /  /
           /                           / d         \\\          /
           |           -v betaa + l[r] |--- Psii(t)|||          |
           |                           \ dt        /||   1      |
   + c[rr] |delta[r] + -----------------------------|| - - b[r] |
           |                  1      / d         \  ||   2      |
           |             -v - - b[r] |--- Psii(t)|  ||          |
           \                  2      \ dt        /  //          \
       /                           / d         \\
       |                           \ dt        /|
-c[rl] |delta[l] + -----------------------------| delta[l]
       |                  1      / d         \  |
       |             -v + - b[r] |--- Psii(t)|  |
       \                  2      \ dt        /  /
           /                           / d         \\         \
           |           -v betaa + l[r] |--- Psii(t)||         |
           |                           \ dt        /|         |
   + c[rr] |delta[r] + -----------------------------| delta[r]| =
           |                  1      / d         \  |         |
           |             -v - - b[r] |--- Psii(t)|  |         |
           \                  2      \ dt        /  /         /
  0
bc;
 / d  / d          \\
 \ dt \ dt         //
            /                           / d         \\
            |                           \ dt        /|
    + c[rl] |delta[l] + -----------------------------| delta[l]
            |                  1      / d         \  |
            \                  2      \ dt        /  /
            /                           / d         \\
            |                           \ dt        /|
            |                  1      / d         \  |
            \                  2      \ dt        /  /
      / d         \
    - |--- Psii(t)| = 0
      \ dt        /
cd;
 / d          \
 |--- betaa(t)| m v
 \ dt         /
            /                           / d         \\
            |                           \ dt        /|
            |                  1      / d         \  |
            \                  2      \ dt        /  /
            /                           / d         \\
            |                           \ dt        /|
            |                  1      / d         \  |
            \                  2      \ dt        /  /
            /                / d         \\
            \                \ dt        //
                 1      / d         \
                 2      \ dt        /
            /                / d         \\
            \                \ dt        //   / d         \
    + ------------------------------------- - |--- Psii(t)| = 0
                1      / d         \          \ dt        /
                2      \ dt        /
