Question: Study Maxwell’s Equations
I'm attempting to use Maple to study Maxwell's Equations, but as a newbie to Maple, I quickly became stuck :-)
For some context, this link shows how it is possible to accomplish this using Mathematica:
https://www.wolfram.com/mathematica/new-in-10/inactive-objects/study-maxwells-equations.html
This is how I have attempted the same in Maple:
Maxwell's Equations
Initialise
with(Physics[Vectors])
[`&x`, `+`, `.`, ChangeBasis, ChangeCoordinates, Component, Curl, DirectionalDiff, Divergence, Gradient, Identify, Laplacian, Nabla, Norm, Setup, diff]
(1.1)
Setup(mathematicalnotation = true)
[mathematicalnotation = true]
(1.2)
Maxwell's Equations
Maxwell_1 := Curl(E__field_(x, y, z, t)) = -(diff(B__flux_(x, y, z, t), t))
Physics:-Vectors:-Curl(E__field_(x, y, z, t)) = -(diff(B__flux_(x, y, z, t), t))
(2.1)
Maxwell_2 := Curl(H__field_(x, y, z, t)) = diff(D__flux_(x, y, z, t), t)
Physics:-Vectors:-Curl(H__field_(x, y, z, t)) = diff(D__flux_(x, y, z, t), t)
(2.2)
Maxwell_3 := Divergence(D__flux_(x, y, z, t)) = 0
Physics:-Vectors:-Divergence(D__flux_(x, y, z, t)) = 0
(2.3)
Maxwell_4 := Divergence(B__flux_(x, y, z, t)) = 0
Physics:-Vectors:-Divergence(B__flux_(x, y, z, t)) = 0
(2.4)
Constitutive Relations
Eq_1 := D__flux_(x, y, z, t) = epsilon*E__field_(x, y, z, t)
D__flux_(x, y, z, t) = varepsilon*E__field_(x, y, z, t)
(3.1)
Eq_2 := B__flux_(x, y, z, t) = mu*H__field_(x, y, z, t)
(3.2)
Solution
We need to get the Curl of H, to take the Curl of both side of Maxwell_1:
Curl(Maxwell_1)
Physics:-Vectors:-Curl(Physics:-Vectors:-Curl(E__field_(x, y, z, t))) = -Physics:-Vectors:-Curl(diff(B__flux_(x, y, z, t), t))
(4.1)
Now substitute B for H:
subs(Eq_2, %)
Physics:-Vectors:-Curl(Physics:-Vectors:-Curl(E__field_(x, y, z, t))) = -Physics:-Vectors:-Curl(diff(mu*H__field_(x, y, z, t), t))
(4.2)
OK, we manage to get Curl of H, so now we need to substitute the Curl of H with an expression in D.
subs(Maxwell_2, %)
Physics:-Vectors:-Curl(Physics:-Vectors:-Curl(E__field_(x, y, z, t))) = -mu*Physics:-Vectors:-Curl(diff(H__field_(x, y, z, t), t))
(4.3)
Well that didn't work, so try to seperate the Curl of H so that we can substitute for D.``
collect(%, Curl(H__field_(x, y, z, t)))
(4.4)
simplify(%)
(4.5)
(4.6)
SortProducts(%, [H__field_(x, y, z, t)], totheleft)
SortProducts(Physics:-Vectors:-Curl(Physics:-Vectors:-Curl(E__field_(x, y, z, t))) = -mu*Physics:-Vectors:-Curl(diff(H__field_(x, y, z, t), t)), [H__field_(x, y, z, t)], totheleft)
(4.7)
isolate(%, H__field_(x, y, z, t))
SortProducts(Physics:-Vectors:-Curl(Physics:-Vectors:-Curl(E__field_(x, y, z, t))) = -mu*Physics:-Vectors:-Curl(diff(H__field_(x, y, z, t), t)), [H__field_(x, y, z, t)], totheleft) = 0
(4.8)
I need to be able to rearrange equation 4.3 so that I can substitute for Curl of H using Maxwell_2.  Any suggestions would be gratefully received!
Download Maxwells_Equations.mw
