Question: Is it possible to show the values of time and a variable when solving a system of ODE with dsolve, numeric before the end of calculation
Hi all,
I'm using dsolve (numeric) for a system of ODE with initial conditions.
Is it possible to show (at the same time with solving) the values of time and an unknown when solving a system of ODE before the end of calculation. Of course, the calculation time is high and I want to know before the calculation is finished if the solution is converging.
Also, I use the option range in my calculations from 0 to 200s (seconds) and more. I do'nt know how I can speed up the solution with less memory.
Please find in the attached file an example.
dsolve1_1r.mw
Thank you in advance for your help.
