Question: question on assume vs. assuming
from help, it says
The expression assuming property calling sequence evaluates the expression under the assumption property on all names in expression.
Then why
expr := Sum((-1)^n - 1, n = 1 .. infinity):
simplify(op(1,expr)) assuming n::even;
does not simplify expr to zero, while
assume(n::even):
does simplify expr to zero.
I would have expected both to give zero.
