Question: On using textit in Latex generated by Physics
I'd like to suggest Physics:-Latex change its use of \textit{} and replace it with \mathit{}
\mathit is the better Latex command to use, since the Latex generated goes into math mode and \mathit is designed to be used in math mode and hence has a better spacing for this. Making the final Latex look a little better.
Here is an example showing the difference.
ode:=diff(y(x),x) = y(x)/(x^2+1);
sol:=dsolve(ode);
Physics:-Latex(sol)
Gives
y \left(x \right) = \textit{\_C1} {\rm e}^{\arctan \left(x \right)}
It will be better to generate
y \left(x \right) = \mathit{\_C1} {\rm e}^{\arctan \left(x \right)}
Here is the difference when both are compiled using latest texlive
Since all the Latex generated is meant to be used in math mode, \mathit would be better choice. It is considered wrong to use \textit in math mode actually, even though it does compile.
Here is the latex file used to generate the above pdf
\documentclass[12pt]{article}
\usepackage{amsmath}
\usepackage{maplestd2e}
\begin{document}
\end{document}
`Standard Worksheet Interface, Maple 2020.1, Windows 10, July 30 2020 Build ID 1482634`
Physics:-Version();
`The "Physics Updates" version in the MapleCloud is 789 and is the same as the version installed in this computer, created 2020, September 1, 23:54 hours Pacific Time.`
sol:=dsolve(ode);
Physics:-Latex(sol)
diff(y(x), x) = y(x)/(x^2+1)
y(x) = _C1*exp(arctan(x))
thank you
Download latex_issue_8.mw
